Working on a pattern that has veins and requires me to use a spiral to eliminate the drill hole. My problem is that is takes me forever to get the spiral locked in at the blade clamp. I cannot seem to get them to flatten out on the ends so they'll hold. Blade keeps coming out and they end up breaking before I get some good use out of them. I went through a dozen when it should've taken a 1/3 of that. Granted they are 2/0 blades but they still will not flatten out and hold. Am I missing something or is there a trick I haven't thought of? I'll get 1 out of 5 to flatten early and hold and thats it. I'll tighten the clamp tension down and they still slip out the back or front. This is causing me aggravation and taking up way to much time. Help please!
Spiral problem
I have had that problem with the quickclamps on a Delta.
You might want to use a pair of pliers to flatten the blade before you start.
I am not sure but small piece of sandpaper folded with the grit together may hold the blades in the clamps. I havn't tried it, just a thought.
There is a new spiral blade with flat ends you can use too.CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
I have the same problem and it bugs the wee wassel out of me to tighten a small spiral and it either pops from being to tight or because it didn't hold in the clamp- both are cause to jump and very frustrating -but there is a way to do it- heres what I do -it may work for you=
make yourself a "wrench" out of PVC and a PVC cap - I use a 3/4 inch- make a + on the top cutting through both cap and pipe the width of your clamp wing - add a1/2 dowel through the other end of your pipe to give you a grip handle-- I have made one because I don't have the strength to tighten the little red screw thingy that is a stupid screw that they think is a so called clamp-- personally I wish they had that screw somewhere south of their waist-- any how you may even try sanding the end of the screw to make sure it is perfectly flat - needless to say mine wasn't but it is now - now as far as the tension goes you need to loosen up on it a bit- especially on the 2/0 spiral it seems to be a big problem on breakage and if i keep mine not to tight it works great - hope this helps .. but there is a solution to most any problem and someone here probably has the answer.
Happy scrolling
Sharon
It's not the tension thats causing the breakage. I believe its the constant clamping and unclamping from it popping out every time I turn it on and trying to flatten it. I've gotta come up with something because of the extra time and not to mention having to buy blades. I'm fixing to try a Zaffino portrait and I'd like to get something figured out by then. Would taking a pair of pliers and manually flatten the blade end first help?Confuscious says, "The cautious seldom err".
it should but I hit mine with a hammer on the anvil end of my vice--when I rember to- but the ends will break and when that happens (if it is just the ends) I just loosen the tension and keep on keeping on with the same blade--they will how ever tend to bend on the end that you put into the clamp and for that I use a square nose non tooth plier to straighten it out. only time i throw away a spiral is if I get the tension to tight and it breaks in the middle-- I tighten the bottom clamp on the blade and remove the top on to load my piece --from the bottom of my work --so as long as the bottom holds I only loosen from the top-- hope this helps
Sharon
spiral blades
Go to this site . Mike has flat end spiral blades .
Smitty
Dewalt 788
I'm not sure what the problem is with spirals coming loose. I use an RBI saw and have had very little trouble holding spirals once I get them installed (that is sometimes difficult because of how they are made). However, as has been said, Mike has "flat-end" spirals and Sloan's Woodshop carries Olson FE spirals as well. I have used the small FE spirals from Olson and they work as well as any blade. The sizes available in FEs is still limited because new innovations in blades have to prove profitable before maufacturers invest the time, tooling, and moola in their production. I won't give any advice on spiral blade tension, etc because I firmly believe that depends a lot on the saw and the operator involved.
MoonOld Mooner
The clamps on some saws have a very precise clamping point between a thumbscrew and an Allan screw. These clamps seem to do a better job on spirals.
Both of my saws, clamp the blade between jaws. If the blade is not flat the spiral tends to collapse between the jaws. As they collapse the friction between the jaws and the blade is reduced. If you purchase the spirals with flat ends this isn't a problem.CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Spirals
Not Sure What Type Saw You Have But If The Blades Keep Slipping Out Your Clamps May Have Formed A Grove In The Holder Themsels. If You Can, Take The Clamps Apart And Rub Them Against Some Fine Sand Paper . This Will Help With Groves And It Cleans Off Excess Oil Form The Blades, And Cleans Them Up. If Only One Side Comes Off Rub The Other As Best You Can . Good Luck---rain Man
Perhaps you should try Pegas spiral blades.
I have tried every one of the so called new and improved ones from another company and didn't like any of them. But they were from the same company (except one) with steel that broke too easy for me.
Since I switched to Pegas I am amazed at the extra sharpness and the strength and quality of that Swiss steel.
Pégas Scroll Saw Blades = Swiss Made Quality
Pégas use's a closely guarded fabricating process that produces crisp, sharp, precisely formed teeth, not found in other blades.
Originally posted by Capt WeaselWorking on a pattern that has veins and requires me to use a spiral to eliminate the drill hole. My problem is that is takes me forever to get the spiral locked in at the blade clamp. I cannot seem to get them to flatten out on the ends so they'll hold. Blade keeps coming out and they end up breaking before I get some good use out of them. I went through a dozen when it should've taken a 1/3 of that. Granted they are 2/0 blades but they still will not flatten out and hold. Am I missing something or is there a trick I haven't thought of? I'll get 1 out of 5 to flatten early and hold and thats it. I'll tighten the clamp tension down and they still slip out the back or front. This is causing me aggravation and taking up way to much time. Help please!your friend Evie
One more idea to try. This depends on what saw you have , but on my yella saws, I leave the blade in the bottom holder, and feed through the bottom of the wood. if the twist on the spiral puts it so the clamp is compressing the blade, instead of actually clamping on it properly, I slide my tensioning lever over a tick or two, raising the arm enough to get the blade clamp screw in a position that will effectively hold the blade, without crimping or smashing the blade, or having it wiggle its way out as the screw is tightened. Once the blade is snugged up with the thumbscrew, i then add the proper amount of tension and shes ready for cutting. As for proper amount of tension its mainly by feel,experience, or lack there-of some say. I never really pay attention to what number on the tensioning lever I actually am going to, because rarely does it go to the same spot each time you tension, or change blades. Go by feel for that. I hope youve got it working now, let us know. DaleDale w/ yella saws
Reply to Question about tilting head sawsby cwmageeThe last time I visited with Denny Winter 2020, I had an opportunity to try out the PEGA Saw that Denny has set up in his store. I was extremely impressed with the saw performance. It will be the saw that replaces my EX21 when I need a replacement. When I visite Denny I was considering purchasing it...
Yesterday, 10:24 PM -
Reply to Harbor Fraughtby Jim McDonaldWhen I worked retail, we would have products plainly labeled "One rebate per address". And people would go ballistic six weeks later when their claims for three or four got shot down.
Can't imagine if it had been in small print like the ads of today.-
Yesterday, 09:46 PM -
by mccrookstonFirst time posting.
I have a Pegas Scroll Saw that is almost 2 years old.
I saw about 1-2 hours a night right now and the speed will slow down and speed up on its own.
Sometimes it will run full speed for a week and then switch to slow for a week.
Any ideas on what might be causing...-
Yesterday, 06:01 PM -
Reply to Harbor Fraughtby will8989That is the one store I physically get sick as soon as I walk in. The odor of rubber is overwhelming and I’m good for 3 minutes before I have to leave. Sure glad other stores aren’t like that. Hmmm maybe my bank balance would be higher if they were.
Yesterday, 03:24 PM -
Reply to Harbor Fraughtby Bill WilsonI wonder if their effort to offer better quality products may have something to do with it. Seems like they want to market themselves as something more than just a cheap tool supplier. Maybe reducing the number of things eligible for the big discount coupons is part of a campaign to change their image....
Yesterday, 02:41 PM -
