Hi All ~
Has anyone got any suggestions about mounting a saw to reduce the vibration ? I am thinking about putting a carpet pad between my saw, Dremel 1680, then 3/4 " plywood under the pad next to the legs of the saw. Would this help or is there another way of mounting it ? I have a wooden work bench I could mount the saw on if it would be better than the stand the saw came with. Mounting it to the floor is not an option. I need to be able to move the saw out of my garage to cut with it. Thanks for any hints or suggestons you may have.
Tony .
Tony .
