blade for ripping oak??
  • blade for ripping oak??
    is there a blade out there designed to cut with the grain? i'm currently using
    a FD-SR #7 and unless i use a brand new blade, the wood is laughing at me. i'm cutting 3/4" oak. what i have been doing for the cuts with the grain is using a new blade every 5-10 minutes of cutting. i'm saving those blades for later use when i'm cutting across the grain.
    Because oak is heavy grained it can at times be very tough. Use a skip toothed blade at least a #7 if no detail use a #9 Also the precision ground or in Mike's case the FD Polar blades work well.
    John T.
      its not very detailed in the area i'm working so i'll give your suggestions a try. thanks.
        Reply to My covid angel
        Great designe! I would have gone a bit further than Linda, Scott and Gladefade I would cut it into more pieces to make shaping easier. Taper the clouds from right to left, taper the wings so that they are lower where they attach to the body. Taper the neck so that it looks like it is going into the...
        Today, 09:02 AM
        Reply to Tough Decisions
        The never ending dilemma. I only get two magazines SSWWC and Wood carving Illustrated. Even if I don't make something in every issue there is usually something in each one that I have never tried and that will either challenge or inspire me. Yes I know that I do test cutting for them and they have occasionally...
        Today, 08:49 AM
      • NC Scroller
        by NC Scroller
        I would start by tracing your piece on a piece of 1/8" (3mm) material and then cut the back our such that it is a fraction smaller that your project. Then I would cut your piece into two pieces. I mean cut the angel from the cloud. I would then put the cloud on the 1.8" backer and then with...
        Today, 07:27 AM
      • Quartz43
        by Quartz43
        I understand supporting the magazine and agree. I just do not find many projects that fit my desires.
        I would like to see them do a poll with subscribers to find out what type projects people want to see....
        Today, 05:42 AM
      • GladeFade
        by GladeFade
        First off how thick is the board you cut?
        When I want something to stand out I use backer-boards 1/8 thick to get the depth.
        that means you would have to cut the big cutting into pieces to put the spacer behind.
        for instance the cloud bottom right which his hand is on I would put maybe...
        Yesterday, 11:05 PM
