This is a good idea but as the tape lubricates the blade when it the blade cuts through the tape, it only lubricate 3/8" each sides leaving 1/4" not lubricated in the wood. Exactly where it generates the heat.
Instead I used the OLSON Saw Blade Lubricant. This is a hard wax stick shaped like a big 1" x 8" crayon. Just push the wax stick into the running blade so the teeth are throroughly coated. The wax will flow when saw blade becomes warm. The cut is clean, smouth, faster and much less burned.
I bought it for about 6$.
Product name: Saw Blade Lubricant
Olsen Part number : OL-7001
