What blade would you recommend to cut 1" Bloodwood.
Right now I used the Gegas #3 Skip tooth and that wood is so hard that it took about 10 minutes to make 4 inches long cut. I changed my blade after each 4" lenght of cut.
No matter what speed I use, it makes some smoke. The stroke of the blade is a bout 3/4" long (this is an average on most saws) this mean that the dust that is more than 3/8" into the wood does not fully get ejected and burns. This wood is an exotic and oly wood, therefore it is prone to burn when cutting, the tickness I used does not help either.
Anyone has exerimented cutting this kind of wood? What blade have you Used? Mike, what blade would you use?
