I just bought an airbrush and hooked it on my 32 gallon compressor and varnished some small pieces of an intarsia project.
I can't believe I did not bought it before. Just dilute the urethane varnish with 10%-15% thinner. And that is it.
Instead of using gel or wipping varnish (most of it end up in the rag when you apply or rub it) I used a few table soup of thinned varnish. I save a lot.
Excell EX4-1 Paintbrush (made by Devilbiss div. of PorterCable) is only 15$ and it fit on compressed air can or compressor any size from the real small ones to the extra large ones.
Hook it through a 1/4" adapter onto your hose, an air pressure gauge and a air filter (to filter humidity) then you could start to spray. If your line is short, you might not need filter and pressure gauge.
