Cross-cut box for the Tablesaw
This is a sticky topic.
  • Cross-cut box for the Tablesaw
    With all the talk of tablesaws recently thought I'd share my plans for a cross-cut box for it. This makes cross-cutting much quicker, safer and makes for very accurate repeat cuts (think box sides). One word of caution....DO NOT attempt to rip pieces with it. I took a shortcut with a small piece once (ripping) even though I knew better and of course the wood pinched the blade, kicked back and thankfully I still have lightning reflexes and managed to get most of the way out of the way (it grazed my neck).
    Anyhow here goes -
    Material listInstructions
    Kevin
    Scrollsaw Patterns Online
    Great design! Thanks for sharing Kevin!
    www.GrobetUSA.com
      Thanks Kevin. I will have to make one of those for my saw. Looks a lot safer than just using the factory miter that comes with the saw. I made one for 45 degree cuts some time back. But I still can't cut a good 45 miter cut with the jig or the radial arm saw.
      www.pajarostudiowns.com
      Excalibur EX-21 fanatic
      One of the Chosen few
        Hi Kevin, the only thing I would add is a wide strip of plexiglass that would go over the blade from front to back of the jig. You can still see what you are doing but keep your fingers out off the blade.
        Alan and Rafi.
        In our house, if you have to bend over to pet a dog it ain't a real dog!
          Thanks Kevin. A solid design for a cross-cut sled. I agree with Alan about the piece of plexi or lexan to cover the blade path. I made one for myself when I first got my table saw and have almost worn it out with use. The next one will have two runners instead of only the one I put on the original.
          george
          George
          delta 650, hawk G426
            Jediscroller great job!
            Question:
            The Top Reinforcement Rails are they strong enough to hold the sled together when you need to take the whole thing off the table?
            I surfed the web for weeks until I found this site.
            Super Sled - Crosscut and Miter Sled
            Kevin they have a great way to set up 45 degree cuts. I will be incorporating this into my sled soon.
            Mentioned it here:
            http://www.scrollsawer.com/forum/off-topic/22827.htm
            VB...
            Tool of choice: DW 788, DW 735,
            Aspire To Inspire Before You Expire.
            If you don't stand behind our troops, PLEASE feel free to stand in front of them!
              Question:
              VB...
              VB,
              My apologies...I just now saw your question. I've been using the sled for a couple of years with no problems taking it on and off the saw. The rails are had maple.
              Kevin
                Thanks for the plans.Looks acurate.Tony
                  Originally posted by Jediscroller View Post
                  VB,
                  No worries. Thank you for responding.
                  I have a similar table sled. Your right they are wonderful to work with.
                  VB...
                    Wow! That was an awesome design. I would like to make one for my table saw some day.
                    -Bill
                    -Bill
                      For those who refuse to accept nothing other than the very best accuracy, this article by William Ng shows how to quickly analyze and modify your jig for absolutely perfect 90s. "5 cuts to a perfect cross-cut jig".
