I have been using 3 in 1 oil to lubricate my P-20. The owner's manual says to use light machine oil. The 3 in 1 seems to be pretty thin. What do the rest of you use? Mick.
Delta P-20 owners
Way more information than you ask for
There are two kinds of 3-in-1 oil. Red can (standard) and Blue can (electric motor.)
For high speed rotation lubrication, as in a pivot bearing for a Delta brand scroll saws, you should be using the blue can oil which is for electric motors. This is basically SAE 20 weight non-detergent motor oil. It is formulated not to turn into glop due to the rotation friction of the moving parts.
Red can oil will turn into glop. This glop must be cleaned with non-scratching and non-metal kitchen scrub pad and paint thinner.
You could also go to a consumer automotive parts store and get SAE 30 weight non-detergent motor oil in a quart can for just a few dollars which would last the rest of your life, but storing, and dispensing is problematic.
In the N.E. USA, where there is a lot more Home heating using the Hot Water systems with water pumps, there is available in the plumbing and heating stores, an extra refined, higher viscosity machine oil for use on the motors and pumps. This you should not use.
Aside: Many Delta scroll saws use a friction pivot bearing with a bushing on the top and bottom arm. On occasions, you may have to remove the entire arm assembly to clean and scrub the back side of the arm assembly where the bushing on the arm is in contact with the saw frame. The design of your saw may differ from mine, which is much older.
Phil
by Jim McDonaldSometime back, there was some discussion about darkening oak. I have used the search and found something about fuming with ammonia, but I think there was another method using vinegar.
I have a suspicion it may have been lost in the software change.
Any guidance appreciated.-
Today, 09:10 AM -
Reply to My lucky day!by handibunnyGlad to hear the good news. I admire your ever-present spirit of adventure!
Today, 07:21 AM -
Reply to My lucky day!by jim_mexAfter a lot of misleading communications the Mexican government seems to be finally getting it's act together. I was just sent a bulletin inviting me to present myself at a vaccination station this coming Wednesday.
Still no idea of which vaccine I'll be getting but if it's the Russian...-
Yesterday, 10:44 PM -
Reply to More Miniature Birdhouse Ornamentsby Sandy OaksThanks Pete. Yes, down to only one on the tree....Yesterday, 11:41 AM
Reply to More Miniature Birdhouse Ornamentsby Sandy OaksThanks Rolf. Yes, fun cuts....Yesterday, 11:41 AM
