I have a Delta ss-250, when I removed the pivot bolt from the upper
arm assembly it took some doing but was finally able to pull it out, I found
metal shavings on the shaft. I oiled the pivot bolts as recommended @ every 20 hrs. of use using 3 in one oil and cleaned all the shaving out. I have not used my saw since. When I put it back together I saturated these bolts with oil.
Does anyone have any suggestions to prevent this from happening again?
Bill
Bill
