Every thread seems like my first this and first that... and it is because I am just starting. =) Here is my first puzzle that I just finished cutting... haven't sanded or finished at all yet. My kids will have fun with this one.
My first puzzle
The pattern came from here:
Free Scroll Saw Patterns by Arpop: Oregon State Puzzle Pattern
I have a question on finishing... what is the best way to finish a puzzle? Spray on urathane with the pieces together? Each piece individually? Should I finish the sides of the pieces... the back? Not sure what to do from here lol.
-brad
Looks good, Brad.
For a stand-up type puzzle (as opposed to a jigsaw puzzle with a picture pasted on it) I usually pre-sand the board to 220, and after cutting I give individual pieces a quick pass through a mop sander to soften the edges a bit. For finish I dunk the pieces in Danish oil, wipe it off, and let them dry on a rack made of crumpled aluminum foil.
--Rob
I do pretty much the same thing Rob does, except I use paper towels instead of aluminum foil, and I give the oil a chance to dry before wiping it off.
Take a scrap piece of the same wood and try dipping it in Danish oil. Maybe you'll like it better that way. It brings out the colors in the wood and protects from oils in fingerprints.
Nice job!
Reply to Question about tilting head sawsby handibunnyIt doesn’t matter whether the saw table tilts or the saw arm tilts. Either can be used for any project cut at an angle, and there’s a learning curve for each.
I actually prefer the tilting table because the blade remains vertical. I find that at really steep angles, like 40 or 45 degrees,...-
Channel: Welcome Members
Today, 02:10 PM -
by will8989This is the tapestry I found in the cedar chest. We can’t identify where the pictures are from. Two among many. I also forgot to mention dad was also in the army Fife and Drum Corps and also played with a big band when he was discharged. Have to find that info....
Today, 12:34 PM -
Reply to Bruce doing greatby will8989What a morning. The therapists were quite pleased with what he could do. He took the wrap off today and he can walk with the walker with very little pain. It’s getting the leg completely straight that is hard to do. It’s when his brother stopped in that things went off rails. Rolf, we are talking...
Today, 12:19 PM -
Reply to Question about tilting head sawsby Sandy OaksIf you are referring to 3D Compound cutting, the blade is 90 degrees to the table and not tilted. I use the tilting head for things like inlays and Carole's bowls. If you want a tilting arm, be sure it is rack and pinion. Look at other features that may fit your needs. As a Pegas dealer, I can help...
Today, 11:32 AM -
by Jim LowderI think the foot release was an option. I don’t see the pulley for it on the back of yours. Although it may have been removed. It is a very simple concept, it’s a cable attached to the back of the saw to release the arm
Today, 10:10 AM -
