Hi Everyone, I have a non-puzzle question for those who use a dry mount / laminating press. Recently, I made a couple of clipboards using either scrapbook patterned paper or one of my photos. I purchase the blank clipboards at Michaels, then mount and laminate the image, however I find that the laminating isn't hard enough and that if it is used to write on (as clipboards are made to do) the writing is impressioned into the laminate. Does anyone have any ideas on how to make the laminate hard enough or is there a specific material I should be using as a laminate? I use Finish Guard laminate and put it in the heat press for about 6-7 minutes @ 225 degrees.
Any ideas or comments are appreciated!
