How many of you use the so called puzzle blade?
Blade ?
Me. I use it, not exclusively, but rather sparingly.It, like every other blade out there, has its place. Its a great blade for cutting BBply 1/4th inch thick (or a couple layers of 1/8th inch). Its not a good choice of a blade though if your planning on cutting the 3/4th inch thick wooden standing animal puzzles and things of that nature.What do you have in mind???Dale w/ yella saws
Yeah, I agree with Dale. It's designed to be used with 1/4 (maybe even 5/16 or so) or thinner plywood. It's narrow kerf allows for very tight turns quickly. I get about 50 puzzle pieces out of BB before changing blades. With the 5-ply poplar I use most often, I can get three times that.
Carter
I, too, use the puzzle blades for 1/4" BB puzzles. For 3/4" standup puzzles, I use a #5 or #7 depending on the type of wood.
John
For me, the puzzle blade have too much drift. I prefer a 2/0 scroll reverse. My puzzle piece is tight and I've experienced a lot less drift. My 2/0 is for max 2 x 1/4" BB in stack. For a 4-5 stack cut, I use a #3 scroll reverse.
2/0, #1, #3 scroll reverse and 2/0 spiral are the only blade I have.
(oh...I have a strong FD-HD - Heavy-duty blade too ;-)
My 2 centLast edited by mels33; 11-10-2011, 01:08 PM.
Today, 03:24 PM -
Today, 10:23 AM -
Today, 10:19 AM -
Today, 07:55 AM -
Yesterday, 08:15 PM -
