I am trying to understand if I had a Etsy store, would I have to collect sales tax for the buyers state? I thought that was only if you had a business presence in their state, but the Etsy documentation wasn't very clear. It made it sound like you did have to collect sales tax.
Etsy and state sales tax
Originally posted by bstark View Post
But do they send the sales tax to the states, or do does the store owner?Dan in So.Ca.
- Likes 1
Little late to the party here, You are responsible to remit the collected tax from the state in which you are selling from.. Etsy handles all the other states. All the replies above make it sound as if etsy does it all.. which they do except the state in which you are selling from.Kevin
www.KevsKrafts.com
Reply to Wood lampshadeby RolfReally nice work! I personally prefer a Semi gloss or Satin finish. The only time I may use a gloss finish is on some wood turnings.
Today, 07:44 AM -
Reply to Wood lampshadeby planeurHere is somes of my inserts , in ebony , and I put to reinforce at the back of the bird (chickadee ) a MDF with real wood on each side , total of .096" , because the cuttings was very delicates ! Still have some sanding on a couple of them!
Not finish yet of cutting inserts , I have...-
Today, 07:03 AM -
