What is the best blade to cut 1 1/2" wood
Blades
My preference would be Flying Dutchman #5, as it could handle it if you needed some tighter turns---and going to a #7 or #9 if doing a lot of straighter cuts. Plywood does dull blades a bit faster though, no matter the blade brand choice. The best blade is kinda a broad question---every brand works a bit better or worse for each person depending on the saw, tension, wood, feed rate, and experience of the scroller.Linda at www.ArtIngrained.com
- 2 likes
I have been cutting a lot of 1 1/2 hardwood for mini birdhouses and my go to blade in the Flying Dutchman UR-5 as I like the finish it gives.
For some real hard woods like cherry and hard maple I have had better luck with the FD polar bladed #5.
I had some cherry that was burning so I tried the Pegas MGT #5 and it worked great. Not a fan of the MGT but in this case worked well. Had to buy some more from Denny.
Sometimes you just have to experiment.
Also, I wrap my hardwood with box tape and it helps a lot.
It really depends. I typically limit my stack cutting to 1" or less. The only 1 1/2" cutting I do is for compound cut projects. For those I prefer a #5 or #7 skip tooth blade. I do not like a reverse tooth blade for these because the reverse teeth does not clear away all the saw dust from the kerf. Since you are stack cutting a skip tooth might not be best as the skip tooth will create more tear out on the back side than a reverse tooth.Scott
I have grown to like the Pegas brand MGT blades . for this thickness the blade number varies from brand to brand, The TPI (teeth per inch) is more important the Pegas 5 is 11.3 and the 7 is 10.4 TPI.
I also the Olson Mach series the #7 has 8 TPI and really works great on thick wood.
And as has been said the plywood is a blade killer.Rolf
by Quartz43Maybe nothing has changed ? But is there anything that can be done to make it easier. The very large projects are difficult to copy over several pages and put together properly. I believe in making improvements and not preserving the status quo.
I enjoy the challenge of cutting a project...-
Yesterday, 08:48 PM -
by keystonecopThis is not a problem with the magazine for my issue.. It is a problem with the book having resized the drawings without giving the actual size.
I do again apologize for my post.. I cannot use the right words to explain it.. so maybe someone should just remove the post....-
Yesterday, 07:29 PM -
by markdavdReading these replies, I am still trying to figure out what the problem really is. I haven't noticed changes in how they publish recently and I don't think I ever had trouble making copies of of the patterns I want to cut.
How did you copy the patterns 10 years ago? What has changed?...-
Yesterday, 06:43 PM -
by Quartz43I am very glad to hear this and that Fox will look into the issue. Hopefully, they can do some things to try to make it easier to copy patterns.
Yesterday, 06:34 PM -
by keystonecopFirst I didn't mean to stir up a hornet's nest. Sorry for that. I will share that Kaylee Schofield reached out to me after my post (not sure if this forum or Facebook. From my past experience with her, she cares. I do believe she will address this issue. I do not think she is the type of person...
Yesterday, 05:36 PM -
