Kleenex box
  • Kleenex box
    First try for that kind of work.
    To thank my sister , I did that box , from her suggestion, and put the flower she suggested.
    Wood is black walnut , 1/8" thick, with this wax
    https://ardec.ca/p/1/cire-a-patiner?...B&variant=2922 .
    Flower cut at the scroolsaw , and I put red marquetry inside for the flower.
    Before the finish
    Once applied
    planeur
    That is sure a beautiful box.
    Denny
    ArtCrafters in Dayton, TN
      Your sister will love it! Very nice on all fronts!
      Linda at www.ArtIngrained.com
        Thanks to all ! Have a good day !
        planeur
          Beautiful box. If you every want to make other designs Sue Mey have numerous box designs.
          Scroll Saw Artist
            Today, 07:36 AM
            Today, 07:29 AM
          • NC Scroller
            by NC Scroller
            Today, 05:29 AM
            Yesterday, 08:46 PM
            Yesterday, 08:45 PM
