This is the beginning of the Aries challange. I love the design, but it is very graphic, and I'm not seeing the intarsia in it. Hopefully someone out there will show me how it's done. To me, it's a perfect inlay or marquetry design, which is something I've been thinking of trying. I have never done a scrolled inlay and I've never turned anything on a Lathe, so I figure I'll do them both at the same time. I shrunk the pattern down to 6 1/4 wide, and it's nice that the pattern is almost square, about 6 1/2 tall. I am going to take a stab at turning this project into a designer plate.
This is only a 21 piece design, but certainly not a design I'd recommend to a first timer. The pieces fit like a puzzle, with alot of complicated curves that run into deadend points on both sides of the curve. I had to stop and turn the pieces into a big gluey mess before completeing the picture portion of my project. There's only 6 pieces left to cut before inlaying the picture and then I'll begin cutting the segments for the outer rim of the plate.
