Advice for next project
I almost always use a #7 blade. If you're going to use western red cedar, a #5 would be ok too. As far a transferring the pattern, I've found the easiest is cut out the pattern pieces. Put packing tape on the wood and spray adhesive on the back of the pattern. Stick pattern to packing tape that is on the wood.Janette
www.square-designs.com
I use a FD #5 Polar most of the time.
for pattern transfer, I use 1 copy of the pattern. Cut your first piece out, then move the pattern to your next piece of wood. Follow the cut line where you cut the first piece, then continue cutting the rest of the second piece. Continue this until it's cut.
I like the mono-chronic look you have on your posted pic.
T
Reply to My lucky day!by will8989🍷🍷MD is a cluster mess. Getting the vaccine is fast. Getting the appointment is another story altogether. The county executive makes the rules for their own county. State says 65+ the jerk that runs this county says no, 75+ then puts a whole bunch of people on a priority list. But, there are state...
Yesterday, 09:18 PM -
Reply to A few Fretwork projects completed.Excellent cutting and choice of woods. I've made a couple of those classics myself. Thank you for sharing, and pushing me to get busy!
Yesterday, 09:17 PM -
Reply to Spiral Blades - Tips & Tricks?Your list is a good one. Tension and feed rate are imperative for me, and like you said---the less major grain differential the better.
Yesterday, 09:16 PM -
Reply to Spiral Blades - Tips & Tricks?by Jim McDonaldI have used some spirals on portrait style cuttings and while I don't hate them, I find my concentration level goes way up with them. If I am thinking 1/8" ahead with a flat blade, my interest seems to be about 1/32" with spirals.
Also, I am not a fan of the jagged edges inside the...-
Yesterday, 08:00 PM -
