How do I inlay narrow parts, especially parts comming to sharp point? Like the interior cuts on this leaf and flower. The leaf will be about 5" long...for perspective.
Inlay narrow or pointed parts
Here's better picture. My point is how do I turn at the point? Or, do I tilt other way to do other side? Or...?Attached FilesLast edited by RegisG; 11-07-2011, 08:19 AM.An old beginner leaping in.
Pleased with my new EX-16.
Ok, first, no you can't come at it from the other way.
It takes a bit of practice, but after a while it becomes second nature. (I'm assuming that we're going off the tutrial and challenge...Just to get our ducks in a row...pun intended). When you're making a counter-clockwise turn, you can turn pretty sharp turns rather easily, however, if you're making a clockwise turn, it takes a little more tact. You'll need to learn to pull back on the wood as you turn, as if you're trying to pull the back of the blade into the corner, (which essentially just what you're doing).
If you did the duck inlay, you've gotten a taste of turns in each direction...Last edited by JimSawyer; 11-07-2011, 11:32 PM.Jim
Rock and Scroll
My Gallery
My Website
Featherwood Woodcrafts
Jim,
I did not do the duck inlay but, I will now before doing this lily...maybe 2 or 3 times. Guess I was getting ahead of myself. The lily is for Christmas so I have time and, if absolutely necessary can cut out the vein. But, prefer to raise it slightly with a shim.
My new saw is due for delivery tomorrow so I'll just get everything lined up to make some duck inlays following directions (for sure).
Thanks,
RegisAn old beginner leaping in.
I occasionally do a poor job on a turn like that and in other areas of my inlays. I correct it by mixing some white glue with sanding dust from my orbital sander and mashing it into the crack or hole. I apply this mixture and squeegee it off with an old credit card. Allow it to dry a few minutes and sand it a bit. The errors will "disappear"Hegner Polymax- 3,Hegner Multimax-3,
"No PHD, just a DD 214"
Reply to Hiby Jim McDonaldGreetings from central Indiana.
Ask your questions, someone here will answer....-
Channel: Welcome Members
Today, 08:27 AM -
Reply to Vintage scroll saw identificationby HobbyhorseTwo corrections to the above: it was 1950 and the saw was an Eclipse brand.
Today, 04:28 AM -
Reply to Vintage scroll saw identificationby HobbyhorseIn 1954 I had one similar to that which had a spring return in the top arm for blade tension. It was set up on a bench for me by my father and had a treadle system to run it ..... I have no memory of the brand of machine.
Today, 01:14 AM -
by RolfI have done them in strips for a while. Thanks for the reminder Carole, I need to make some more of those ribbon boxes.Yesterday, 08:17 AM
Reply to Vintage scroll saw identificationGot it. Your picture was rather dark and could not see the construction.
I still don't think it was mass-produced though....-
Yesterday, 05:57 AM -
