Intarsia as i understand it is "painting with wood" as explained here.
Bought this new dremel 1680 and played with it cutting out figures for mobiles and such. but now wanting to try Intarsia
Ok you use different colors - species of wood to use as shades and hues. as i understand it
heres the kicker that might be answered by some intarsia wise person.
when using 5 species - colors of wood do you stack 5 sheets and cut the intire pattern out of all 5 then pick and choose alternating color scheam off-setting backround colors ect...
or do you cut each piece out of individual color needed? and precision sand to fit
Also most wood ill cut is 1/4th" what blade should i use for uniform saw blade kerf..?
thanks in advance....
