Low priced Slow Speed Grinder
  • Low priced Slow Speed Grinder
    Just got my quarterly Woodcraft flyer and I see that the Rikon 8" Slow Speed Grinder is on sale for $109 down from $159. I'd call your local store to check, though, because the website still has it for $159.
    I see a Rikon 1x30 belt sander with 5" disk for 99$ in there, also.
    Tony
  • Bill Wilson
    Reply to wipe on poly and tack cloth
    by Bill Wilson
    First, follow the instructions on the can, regarding wait time between coats. I would think that for the first couple coats, re-applying while the previous coat was still tacky wouldn't be terrible, but I would warn that building several coats without allowing proper drying time, will extend the overall,...
    Today, 08:50 AM
  • Don in Brooklin On
    by Don in Brooklin On
    I use wipe on poly quite often and I apply 2 thin coats before sanding with 220 or 320. I wipe with a lint free. Someone told me not to use tack cloth as you can leave behind a wee bit of beeswax witch could cause issues later on.
    I make sure that the surface is dry and not tacky before...
    Yesterday, 05:41 AM
  • dwssr2
    by dwssr2
    Question, when sanding polyurethane in between coats, using a tack cloth, is it ok to wipe on poly while the project seems tacky or should a person wait a few hours to let it dry?
    How necessary is it to sand between coats of polyurethane? I am sure people have a lot of different opinions and...
    04-24-2019, 05:58 PM
  • tgiro01
    Reply to Do you know what this Is?
    by tgiro01
    Betty asked: "Where does the responsibility of the maker of an item end and the responsibility of the purchaser begin? My sealife puzzle is purchased by older people due to its complexity but - if they leave it laying around and a child gets a part and chokes, is that my responsibility or theirs?"...
    04-24-2019, 12:20 PM
  • RJweb
    by RJweb
    The problem now a days everyone is sue happy, no matter who’s at fault, RJ...
    04-24-2019, 10:03 AM
