Hi all,
Since this was not obivious to me initially, I thought I might point it out to others that are new. You experienced ones figured this out a long time ago.
When using bottom feed, putting the blade in the upper holder without the blade binding in the feed hole causing the board to jump on startup, just use the project to move the blade directly in front of the holder, slip it in and tighten the clamp.
As I said, to some that is obvious, but it sure sped things up for me.
Steve - Toledo
Steve - Toledo
