What is the last issue of the Scroll Saw Woodworking magazine to have come out, the last one I got was the spring issue #46?
I ask because I had trouble getting that one!
#47 (Summer 2012) has been out for quite a while, and #48 (Fall 2012) is imminent. I've heard rumors of it being seen in the wild, but I haven't seen it myself.
--Rob
Reason: speling iz hard
I agree with you Mark, I am constantly changing or adapting my patterns to suit my taste or the size of the wood that is available to me. Thinking about electronic versions of the patterns, that would be great. But very hard to control. It amazes me how many people have no scruples about sharing....
Bruce I just looked up the Pegas blade and the Flying Dutchman puzzle blade.
So the Flying Dutchman is a bit thinner , not sure it would make a significant difference. Three teeth per...
Project size 6 x 5,5 inches
Perhaps, we could hear from Fox. Maybe they could try some things and see if it makes things better. Or, they can just keep doing the things the same way.
I personally like the patterns to be printed at the artist's intended size if at all possible. Let me decide to reduce or enlarge. If I don't have the equipment to make a copy at 100%, that's my problem not the publishers. We all have our own...
