Idea for booth.
  • Idea for booth.
    I have been playing around with a backing for show booths. I use two 6 foot tables. And never have enough room on the two tables. So I got some plastic pipe and some plastic fence. Here are some pictures of what it looks like. They are very light weight and fold up for travel. Can be put on the table in about 5 minutes. They are quite stable and hold quite a bit of weight.
    If any one is interested in a parts list and measurements for 6 foot tables. Let me know and I will send them private MSG.
    See the post below. I couldn't send the pdf file. So I attached it for all to see or use if they want.
    www.pajarostudiowns.com
    Excalibur EX-21 fanatic
    One of the Chosen few
    Good Idea. Is it just dry fitted together or did you glue it up?
      Just dry fit. that way it will fold up.
        Pajaro Yup would like your notes Rob
        Not be from Lunch.
        Visit My Gallery
        Oily's Gallery
          Yes please Pajaro.
            Booth Plans
            Not the best plans but I couldn't figure how to send it any other way. It will be here for anyone who wants it.
            It is not drawn to scale but the number are pretty close. Any questions feel free to ask.
            I used zip ties to attach the yard fence to frame.
              Thanks! I printed a copy.
              I've been trying to decide on a light weight vertical display surface that takes minimal storage space and you have pretty much given me a solution.
              I'm off to HD tomorrow for pvc!
              Nancy in AZ
              A clean house is a sign of a broken scroll saw!
                What kind of hooks are shown in the pictures??
                  those are some makeshift things I used until I can get some hooks that look good and work. If anyone comes up with an Idea let me know. Thanks.
                  Update on the hooks, I made my own.
                    You might also want to go to Wally World and and buy a black sheet and a white sheet. They are like $4.00 each. The hang them across the back to further highlight you works. BTW, black works for the bulk of projects but white is handy as a back drop for the darker woods.
                      Pajaro, that is a great idea!!! Can you tell me the estimated cost on that (without the fence)? I have been trying to come up with something that is handier, and perhaps this will work. However, the last time I bought some pvc I about dropped to floor on the price...it sure has gone up!!!
                      Thanx for the great idea and sharing!!!
                      ~ Kim
                      www.gonecoastalart.com
                        Thanks for a great idea Pete. I grabbed a copy. I have a show coming up in December and I just have to find the time to put one together.
                        george
                        George
                        delta 650, hawk G426
                          I purchased all the items at Home Depot, with out the fence the Pipe, fittings and hex bolts cost around $15, the fence was around $10 for a 25 ft roll I made two of these and had lots of fence left over. I don't know if it was marked down or not. But it was the only roll they had...
                            Looks great.
                            One thing I noticed is it looks like a little bump on one of the sides might cause the entire thing to fall. If this is the case, you might want to find a way to attach the sides to the table to keep them from moving .
                              Mark the sides are attached to the table with four 3 1/2 long 3/8 inch hex bolts. I have hung about 30 lbs of wood work on it and it is very stable. Even with the joints only dry fitted together.. The yard fence material is zip tied to the pipe which makes it stronger.
                              • Dan A
                                Blades and Square Blocks
                                by Dan A
                                Today, 06:33 AM
                                Reply to Another Celtic cross
                                Yesterday, 09:47 PM
                              • Harry
                                Reply to Toy jeeps
                                by Harry
                                Hi Jim.
                                sure you...
                                Yesterday, 01:18 PM
                              • jim_mex
                                Reply to Toy jeeps
                                by jim_mex
                                Yesterday, 10:15 AM
                              • jim_mex
                                by jim_mex
                                Well done!
                                Yesterday, 10:12 AM
