Everytime I try to cut intricate patterns with the scroll saw I get breakage of the wood that is not suppose to come out! What am I doing wrong??? I have a Hegner Multimax 18.
Fretwork and Intricate Scrolling
Re: Fretwork and Intricate Scrolling
Don't know but could be -
* Using too aggressive a blade for the thickness & type of wood. You should have 3 to 4 teeth in the wood at all times.
* Putting sideways pressure on the wood instead of straight into the blade
* Trying to cut faster than the blade is capable of
* The wrong kind of wood ... A soft grainy wood won't hold the detail that a hard tightly grained wood will.
hope that helps
Reply to Shawl pinsby axor
Yes, they can be used for hair. If they are made a little larger than the original, the shawl pins will work great in the hair!...-
Today, 03:21 PM -
Today, 09:21 AM -
Today, 09:06 AM -
by cwmageeCarole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
Today, 08:40 AM -
by RolfThat is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
Today, 07:28 AM -
