Production work
  • Production work
    Here are 5 of the 70 pieces I cut for a spiritual retreat coming this September. They are cut from 1/8" baltic birch stacked 5 high using a #1 Pegas Modified Geometry blade. They will be dipped in a 50/50 mixture of shellac and denatured alcohol.
    Look good, do you see fish in your sleep, RJ
    Life Begins @ 190 MPH
      RJ not only do I cut fish, but I live on a large lake and I try to fish as often as I can.
        Steve,
        Karl
          Today, 07:36 AM
          Today, 07:29 AM
        • NC Scroller
          by NC Scroller
          Today, 05:29 AM
          Yesterday, 08:46 PM
          Yesterday, 08:45 PM
