Scrollsaws
  • Scrollsaws
    I am looking for a new scrollsaw. Locally I have 2 options 1 is a porter cable with stand 18 inch table the other is a central machine. Is either one any good. I have a craftsman now. It is over 20 years old. Thank you in advance
    Tricia
    No direct experience with either but from what I have seen posted on various forums and Facebook the Porter Cable is the better of those two.
      Thank you. I have just about wore out my craftsman. Looking for a new saw just can't afford the top notch an that was all the stores had available
      Tricia
        I learned a long time ago that the most expensive scroll saws are not necessaryly the best saw. I have used most all the saws out there and so far I like my Excalibur about the best but have found other used saws I've used I like almost as well.and are much cheeper. My favorit saw that I still use today broke down about a year ago. The "connecting rod bearing holder" broke and I found I could not get a new part so I went out and bought a cheep used 24 inch Delta that I have grown to like and use quite a bit. Before I fixed my Excalibur I also bought another used 19 inch Excalibur scroll saw. Since I could not find a new part for my busted Excalibur I tore it appart and fixed the broken part using Marine Tex Epoxy and reparied the broken part. It works great and just may out last a new part. I now have 3 good saws in my shop and they all work very good. The good thing about the Delta is that it was cheep, works good and does not have many moving parts that can brake down.
          A couple of years ago this magazine did a scrollsaw article about various saws, comparing them. Porter Cable ranked well at the time, for that price point.
          Linda at www.ArtIngrained.com
            One other thing I would like to pass along here is to try and stay away from saws that viberate a lot. I once owned a Craftsman and by the end of a long day my hands & arms would be very tired and sore due to the viveration. They may be considered a good saw but by the end of the day you could be pretty sore. The good thing about the Delta I showed above is that t is a lot ;like a sewing machine, The viberation is mainly from the blade giong up and down.
              Search for a used hegner. Parts are readily available and their service Dept is top notch. My first one was a craftsman and hubby bolted it to the workbench it was on. Then I switched to a bandsaw than my Hegner 21 years ago.
              Betty
                Ray at Seyco has the parts for the Excaliburs as long as it isn't one of the more recent Chinese clones.
                  Thank you Everyone for your advice. I bought a Dewalt. Eugene I also had the same experience with the craftsman. I have only had time to cut a couple pieces of my project. But so far I love it an can see a big difference also alot quiter
                  Tricia
                    Today, 07:36 AM
                    Today, 07:29 AM
                  • NC Scroller
                    by NC Scroller
                    Today, 05:29 AM
                    Yesterday, 08:46 PM
                    Yesterday, 08:45 PM
