A modified Sue Mey pattern to fit 1" x 4" x 10" Hard Maple. Cut on the Pegas scroll saw using a Pegas #5 MGT blade. One side says "TEACH". Flip it over and the other side says "LEARN". After sanding, dipped in diluted Shellac, sanded again and another dipping. Comments welcome.
Teach - Learn
Reply to Wood lampshadeby RolfReally nice work! I personally prefer a Semi gloss or Satin finish. The only time I may use a gloss finish is on some wood turnings.
Today, 07:44 AM -
Reply to Wood lampshadeby planeurHere is somes of my inserts , in ebony , and I put to reinforce at the back of the bird (chickadee ) a MDF with real wood on each side , total of .096" , because the cuttings was very delicates ! Still have some sanding on a couple of them!
Not finish yet of cutting inserts , I have...-
Today, 07:03 AM -
