Scrolling brass letters
  • Scrolling brass letters
    Anyone have advise on cleaning up the roughness from cutting brass letters out of .032 hobby brass sheet?
    Cutting on it for the first time and it's not too bad to work with.
    Go to auto parts store and get a "points file". It's what we used to use to file pits out of contact points in the distributors. Very fine teeth.
    I would make sure the court is very flat on a substrate before filing. That thin could fold easily.
      I would sandwich the brass between two piece of 1/8" plywood and then cut with a very fine reverse tooth bladed (2/0, #1, or even a FD puzzle blade). If you do this method you should not have any rough ends to worry about.
        I have a set of jewelers files. You could also glue a some 300 grit wet dry paper to a thin piece of wood.
        Jim never thought of the points file, great idea! I still have a couple somewhere from my old analog electronics work polishing relay contacts.
          Thank all,
          All great ideas. I did cut between two sheets of 1/8" ply, cut with a 2/0 jewelers blade. Zona is the name of the blade, never heard of them before but they were right there next to the brass sheets so I gave them a shot. They work well. The drill bits left a bigger burr than the blades. I'll have to find a fine file. Think I have one out in the shop.
