Propane Heater Safety
  • Propane Heater Safety
    I was wondering if it is considered safe to operate a propane heater in a garage while scrolling and/or sanding? Obviously, lots of dust is being generated. I don't currently have any dust collection in place.
    Would an electric heater be safer? I am assuming an plug-in electric heater puts out less heat and costs more to operate then a propane heater.
    -Alan
    Excalibur EX-II, Delta 40-560
    I have used both kerosene and propane at different times in different shops. Dust like we make in a one man shop scrolling and sanding should not be an issue with these open flame type heaters. You should use care if spraying lacquer, shellac or any oil finish close to the running heater. WHAT YOU MUST DO is install a Carbon Monoxide and smoke alarm. Also you will need a window or door to provide some fresh air.
      Alan,
      You do not say where you would be getting combustion air for a gas heater. I would a bit dubious in using either heater in a dust laden atmosphere. Electric heat produces a very dry heat as a result static electricity is apt to more common.
      That said presently I have a dust collector (dust deputy) and my propane gas heater takes the combustion air from outdoors.
      cwmagee
      aka Fibber
      Producer of fancy firewood​
        Originally posted by cwmagee View Post
        Alan,
        I am considering the simple propane heater that sits on top of the 20lb refillable propane tanks.
        I would leave my garage door open half a foot to get fresh air in the garage. I would also have a Carbon Monoxide detector in the area for safety. I guess the sawdust would be my biggest concern. Perhaps if I had a dust collector that would eliminate he risk of fire.
          I realize that a dust collector does reduce amount of dust in the air, however I would be concerned with the open flame of a simple gas heater because the dust can be a flash point. That is why I have a gas heater that uses air from outside.
          cwmagee
          aka Fibber
            I see it a bit differently then my buddy Fibber. While it is best to cautious, I have been in many very dusty shops heated with kerosene or gas and they never had a fire. Wood dust is not as exposure or flammable as grain or chemical dust. Follow the safety rules for your heater, specifically distances from flammable surfaces and you will be fine.
            If you were creating enough dust to be a fire hazard I would be more concerned about your respiratory health.
              I am assuming that it is a radiant heater, since it is mounted on top of the tank. Like Scott said get a digital CO monitor.
                It is a radiant heater. I will have a CO monitor near the heater.
