My 1st Scroll Saw Project
  • My 1st Scroll Saw Project
    Here is a photo of my 1st completed scroll saw project.
    I'm happy how it turned out being my 1st project!
    Very precise cutting! Nice
      Very well done, especially for a first. Nice clean cuts.
      Denny
      ArtCrafters in Dayton, TN
        Pretty intense pattern for a first cutting. Great work.
          You certainly picked an ambitious first project. Nice work!
          cwmagee
          aka Fibber
          Producer of fancy firewood​
            Very good work.
            Larry
            Larry Davis
            Using wood rescued from the fire pit. My story told with a log.
            Member Callahan Area Woodworking Group, Clyde, Texas
              Nice work.
                Much braver then I was when doing my first cut. Lettering looks good. Welcome to scrolling.
                Melanie from East TN
                  Wow.. for a first cut that that is great..
                  The other John A. Nelson
                  johnsworkshop.com
                  sigpic
                    Great first project. Keep up the good work!
                    "Time to Give Back"
                      You obviously have some skills, text and circles are some of the most unforgiving things to cut. You did a great job.
                      What kind of scroll saw do you have?
                        I have a WEN scroll saw I purchased via Amazon.
                        I just go slow as I cut out the curves and letters.
                          Are you using pinned blades or does it have the adapter for pinless?
                            Great work
                              The saw has an adapter and can use both pinned and non-pinned blades. I use mostly non-pinned blades by Olson or Flying Dutchman.
