Pegas blade holders
  • Pegas blade holders
    Is anyone with a ex21 using these blade holders tell me about them is it worth the money etc ???
    I have had them on my EX21 for about six months. What a difference. I noticed less vibration. Well worth the price.
    Denny
    ArtCrafters in Dayton, TN
      Prior to upgrading I replaced the tips several times and the clamps with OEM parts and was about replace then again when the Pegas Clamps hit the market.
      I been using the PEGAS clamps for approx. 20 months.
      I rarely have a blade slippage since the upgrade. I have lost track how many operating hours I have on them close to 200+. As far as I am concern they are worth every cent.
      As Denny mentioned less vibration so I able to run the scroll saw hat higher speeds.
      cwmagee
      aka Fibber
      Producer of fancy firewood​
        Thats fantastic thank you VERY much !!!!!!
          I also installed them on my EX21. With the EOM blade holders I always had an issue with small blades, size #1 and smaller, bending at the tips no matter how I adjusted the clamps. With the new clamps they worked great right out of the box.
            Disclaimer: I sell the clamps.
            Part of the reason that you see less blade slippage is that you can easily adjust the set screw opposite to the thumbscrew to ensure the blade is centered in the clamps. On the OEM clamps, you need to break loose the threadlocker holding the set screw in place, unscrew the set screw the whole way, clean out the threads on the screw and in the clamp, apply more threadlocker to the screw and screw it into place, hoping to get it into the correct position before the threadlocker grabs.
            The set screw on our clamps is locked in place with a nut. To adjust the set screw, loosen the nut and back the set screw out a bit. Position the thumbscrew where you want it. Then tighten the set screw up until it's against the thumbscrew and tighten the nut. No threadlocker required.
            Please let me know if you have any other questions.
            Best Regards,
            Bob Duncan
            National Sales Manager--Woodworking
            Grobet USA
            www.GrobetUSA.com
              I see you got your question answered, but I will add that since I put them on my DW788, I have never had any second thoughts.
                Agree with everyone. I have the EX-21. The set screw with nut works well to keep the blade positioned exactly where you want it.
                Jo Labre - in beautiful Racine, Wisconsin
                Mostly, I don't know what I am doing - but I am doing it with GUSTO!
                  Best Regards,
                  Bob Duncan
                  Grobet USA
                  Bob, I lost the nut that holds the set screw. It must have fallen off into nowhere land. Is there a replacement available?
                  Denny
                    Denny,
                    We do have them available. I'll put you in touch with a retailer; if anyone else is looking for one, please let me know.
                    www.GrobetUSA.com
                      I would assume it is an ordinary metric nut that would be available at your local hardware store. probably 4 or 5 mm
                        Have had them on my EX-16 for about 6 months and they work better than the stock Excalibur ones.
                        Less slippage and hardly any breaks that aren't due to my using them to the point of the blade snapping from heat friction.
                        Good investment IMO
                        Woodtography - photography in wood
                        http://www.Woodtography.com
