Magnify light
  • Magnify light
    I'am looking for a good quality light and Magnify what do anyone suggest????
    I bought this Mag lite from Judy Gale Roberts at Intarsia .com.
    It is excellent it has two lens.
    https://intarsia.com/collections/har...agnifying-lamp
    cwmagee
    aka Fibber
    Producer of fancy firewood​
      Doing demos for a club I have used several over the years. The best one I have found is the one Fibber mentioned above. Yes there are cheaper ones but you get what you pay for. Like Fibber I bought mine from Judy.
        I have a couple of the Brittech magnifiers that I bought from Amazon. I am pleased with their quality. But I like the idea of getting the two different lenses, although once you get setup with the magnification you are comfortable with, you probably will never change the lens. . They should definitely have at least a 5" lens and LED lighting. do not go for the fluorescent bulbs.
        This is something to consider 3 diopter = 1.75x magnification at 13” focal length 5 diopter = 2.25x magnification at 8” focal length.
          Like Fibber and Scott, I have the same one from Judy’s place. We probably all bought them when we were in her beginner’s class. Rolf is right, unless you start out with the lense of lessor magnification and then need to move up you probably are not going to switch out the lenses. However, it was good to be able to choose which one works for you. Also, this one does not have the distortion around the edges like some of the cheaper ones do.
          I had gotten this one, but I have two saws so wanted to add a light to the second one. Thought I would try to save some money and got a cheaper one in a local store, but it had the distortion at the edges and seemed to throw shadows the one from Judy did not. I quickly got rid of it and bought a second one from Judy. I wouldn’t be with out my light and magnifier.
          One final note, some people cannot use these because it gives them double vision for some reason when looking through them. Judy mentioned this once at a class, and said she had only had one or two people in all the years of teaching her classes who couldn’t use it for that reason. I found that a little strange, but then my husband had the same issue with mine. I still don’t know why that is. So if you have never used one before, be aware of this potential issue for a few folks.
          Melanie from East TN
            I wear progressive glasses all of the time, they already give me some magnification. When using a magnifier I have to make sure that the focal point of the lens is correct and then move my head until all is clear. This is all automatic but if not correct I will get a mild double vision effect.
            Mel does hubby wear glass?
              I wear no line bifocals. I bought a lamp through Amazon and had blurred vision. Got an almost instant headache. The one I got from Judy gives me no issues.
                I also wear transition glasses. I have no problem.
                Regarding changing magnification Rolf I agree it is rare to change the magnification. However I have found a few instances where I found it more comfortable using higher
                magnification.
                cwmagee
                aka Fibber
                  Rolf, No, he doesn't wear glasses but he did have lasik surgery several years ago now. He was very far sighted and did wear glasses since he was little. I think if I remember correctly that when they did the lasik that they did one for closer and one for father away. That may have something to do with it perhaps. I will have to ask him if I am remembering that correctly though.
                    Try this one https://www.harborfreight.com/Fluore...amp-60643.html
                    This is my second from Harbor Freight. (I broke the first one)
                    I have progressive lens glasses and have not had any problems.
                      I have a fluorescent ring magnifier that I rescued from work It had a broken joint. Used it for years until I bought a LED version. The Light is so much brighter on the LED. I was always worried that the upper arm on my Hawk would pop up and break the tube.
                      • Bill Wilson
                        Reply to wipe on poly and tack cloth
                        by Bill Wilson
                        First, follow the instructions on the can, regarding wait time between coats. I would think that for the first couple coats, re-applying while the previous coat was still tacky wouldn't be terrible, but I would warn that building several coats without allowing proper drying time, will extend the overall,...
                        Today, 08:50 AM
                      • Don in Brooklin On
                        by Don in Brooklin On
                        I use wipe on poly quite often and I apply 2 thin coats before sanding with 220 or 320. I wipe with a lint free. Someone told me not to use tack cloth as you can leave behind a wee bit of beeswax witch could cause issues later on.
                        I make sure that the surface is dry and not tacky before...
                        Yesterday, 05:41 AM
                      • dwssr2
                        by dwssr2
                        Question, when sanding polyurethane in between coats, using a tack cloth, is it ok to wipe on poly while the project seems tacky or should a person wait a few hours to let it dry?
                        How necessary is it to sand between coats of polyurethane? I am sure people have a lot of different opinions and...
                        04-24-2019, 05:58 PM
                      • tgiro01
                        Reply to Do you know what this Is?
                        by tgiro01
                        Betty asked: "Where does the responsibility of the maker of an item end and the responsibility of the purchaser begin? My sealife puzzle is purchased by older people due to its complexity but - if they leave it laying around and a child gets a part and chokes, is that my responsibility or theirs?"...
                        04-24-2019, 12:20 PM
                      • RJweb
                        by RJweb
                        The problem now a days everyone is sue happy, no matter who’s at fault, RJ...
                        04-24-2019, 10:03 AM
