Finishing
  • Finishing
    Have not posted here in awhile, have moved over to Facebook for most posts and Questions. So I will share a facebook post that I made.
    Cut more things than I thought over the Summer. Sacramento in the 80's so tomorrow everything gets a bath for about 10 minutes in WATCO natural oil. Then rest for about an hour, wipe off and spray with air. Back into the box with fresh newspapers . Will wipe them down again after that one more time. Then a few days rest. Everything except the trivets will get a couple of coats of DEFT semi-gloss lacquer spray. Why did I post? to share how I do it, and get last minute advice.. Thanks in advance.
    The other John A. Nelson
    johnsworkshop.com
    sigpic
    I don’t have any advise as you are doing what I do, but I do have a question. Where did you get those trays? I used to have a diabetic dog that required special food from the the Vets office. A case came with trays about the size of yours. He has been gone for a few years. I still have some and use them like you do, but the are getting old and wearing out and soon will have to be replaced.
    Dan in So.Ca.
      my wife picks them every time she goes to Sams Club... So Sorry they changed the boxes. mine are worn and stained.. but usable.
      johnsworkshop.com
      sigpic
        Thanks for the tip.
          John. looks like you are into mass production.
          Denny
          ArtCrafters in Dayton, TN
            Only on a couple of Items.. Started with making whirligigs about 20 years ago.. got to the "I hate to paint" stage and moved on to fretwork.. Now I am into the hate to finish stage.. (better than painting) I wait to do a lot at one time to save on cleanup..
            johnsworkshop.com
            sigpic
              I need a wait and see timeout. Used Watco Natural 275 VOC Danish Oil , which is new to me. Got sticky after about 10 minutes of drying time. Looks ok. time will tell. Never got sticky before , used Natural 350 VOC Danish Oil which I had to get in Nevada.. A California thing. I sure hope it will work. so far the end grain looks better , just worried about what happens when I give it a lacquer spray.. I will wait a time with Patience.
              johnsworkshop.com
              sigpic
                Thank John for the tips. For "dipping" I use Deftoil Natural.
                I hear many products we use every day, such as mineral spirits and even turpentine, are now banned in the Left Coast.
                  Advent wreath
                  For one of my good customers. From the fall issue 2016. Cherry and African mahogany. Bruce turned the candle holders as we couldn’t find candles to fit any already made wooden holders. I used the green sparkle unicorn spit over green paint for holly leaves and red for the berries. Yes, I actually...
                  Yesterday, 11:39 PM
                • Ennobee
                  Reply to 10" long truck.
                  by Ennobee
                  Looks pretty neat. So it's from a 2x4: 3 in wide, 'bit less then 2 in. high? So how did you get the trunk cut out? You mentioned cutting the sides with a scroll saw, did you slice off two sides and then cut out the middle?...
                  Yesterday, 09:46 PM
                • vgraf
                  Reply to sanding sealer or shellac
                  by vgraf
                  I use sanding sealer on baltic birch plywood, pine and birch if I am going to stain them. Without the sanding sealer, the stain will be blotchy. I use the water base sealer from minwax. After it drys I sand to at least 150 grit and often to 220 grit. Wipe it with a tac cloth then apply the masking...
                  Yesterday, 08:27 PM
                • Jim Finn
                  by Jim Finn
                  We, our club, delivered over 900 toys last week to The Salvation Army, Ronald McDonald House, and a local children's hospital. Included were most of these trucks. (I sold a few)
                  Yesterday, 07:17 PM
                • NC Scroller
                  by NC Scroller
                  The real nice thing about using shellac and alcohol mix for ornaments is you only have to wait minutes before you tie in your ribbons and packaging.
                  Yesterday, 10:48 AM
