Cutting 36" long piece.
  • Cutting 36" long piece.
    Hello all, it has been a while, i have been trying to cut a 1/4" piece of MDF which is 30" long and about 28" wide. Any advice or suggestions as how to cut. I tried a spiral blade and they are just so difficult to cut with. A while back i read something about taking a regular blade and twisting it on top and bottom... i tried it once and would not stay in the blade holder....
    please help... suggestions appreciated.
    I have no idea how you would cut something that size with out using spiral blades. I'd say practice with spirals until you are comfortable with them, then go back to your project. I use spirals when needed. My two spirals, and the only one I use are the Flying Dutchman New Spiral blade size 3/0 and the Pegas spiral size 2/0. Start out slow, don't try to force them you will gain some speed as you get use to them.
      thank you.. have you ever tried twisting the blades top and bottom so you are cutting basically from the side of the table??
        Practicing with a spiral blade is really your only choice - I'd agree with cutting at a slow speed and feed rate - couple other thoughts - maybe sandwich your 1/4 inch board so the blade has a bit more resistance if it is cutting too easily or aggressively - use a finer blade rather than a coarse blade - keep good tension on the blade - work on keeping a smooth and steady flow to your movements (if you were just learning how to drive remember back to the advise to keep your eyes way down the road - not on the pavement right in front of the car) - I'm also assuming you have good, level support on your work either side of the cutting table - and also assuming your saw is well tuned (blade vertical from side to side and front to back) and finally - remember the first point - take time to practice and feel comfortable with a spiral blade before committing yourself to your project - hope this all makes sense.
        Jay
          Just another possible solution, place the blade in backwards. - Floyd
            How large is your saw. I cut 30" on my 226 Hawk saw. But you have to come at each cut from 2 angles because you can not spin it 360 degrees. Mirror is 30" wide
            John T.
              I cut a 30" + door topper and for some cuts it did as Floyd suggested and put the blades in backwards. Make sure you practice with the blade in backwards. It is very different.
                I have never tried cutting anything that large.
                Denny
                ArtCrafters in Dayton, TN
                  It takes alot of practice to ge the hang of spirals but once you do, your hooked. It took me two times of trying to get the hang of spirals the first time was a big fail I got so frustrated with them I wanted to throw the blades and saw across the room. I put the blades up and months later out of pure bordem and wanting a new challange I got hte spirals back out. I turned my saw down to the lowest speed got some scrap wood and starting praticing and slowly worked turning the speed of the saw up till I got the hang of took about a hour but was able to use spirals after that I was hooked.
                  Try the spirals again just go slow take your time and pratice on scrap wood draw lines and shapes and practice cutting those out till you get the hang of it.
                    If you want to try twisting the blades again, this works for me.
                    Install the blade , using pliers grab at the top and the bottom at the same time, twist 90° and then tension.
                    Hegner Polymax- 3,Hegner Multimax-3,15" Jet
                    No PHD, but I have my GED and my DD 214""
                    • Sandy Oaks
                      Reply to One For My Quiting Wife
                      Sandy Oaks
                      When people come into ArtCrafters and ask about a scroll saw, I say it is similar to a sewing machine except with small blades.
                      Today, 03:22 PM
                    • leehljp
                      Reply to Interesting Hegner Patent
                      leehljp
                      Me - also! I drove from Memphis to Dallas yesterday in heavy rain all the way. Could not use the cruise control. My leg was in a knot.
                      Having said that, I can sit still at the scroll saw for about an 30 minutes at the most before I have to move around; On the lathe, I can also stand in...
                      Today, 11:51 AM
                    • tgiro01
                      Reply to Super Max 19-38 real test.
                      tgiro01
                      I've lured a husky neighbor with the promise of a turned pen. Now we are just waiting for the d()*& rain to stop so we can get the minivan around to the back steps into the basement, and get it down stairs. All my neighbors know that, when they help me - they walk away with a priceless work of art...
                      Today, 10:47 AM
                      Scrappile I like that engine hoist. When we moved into this house back in 96 One of the first things I did was put a loft in the garage and provided a place to hang a chain hoist for working on my car. The roll around hoist has some advantages over my setup.
                      Today, 10:30 AM
                      I have two variable speed controllers one is on my Digital embroidery machine(inherited from my Mom) and I also have a Rampower carver with the electronic foot pedal. The variable speed on both of those gives much more control. especially on the power carver....
                      Today, 10:22 AM
