US Warships Patterns
  • US Warships Patterns
    I am looking for a pattern to scroll saw of a US Destroyer. I can't locate anything even close. I think it would be a good new book for veterans having served in the military
    Re: US Warships Patterns
    You may end up having to make your own. If you do try images on google, that should net you a bunch of pictures. If your unfamilliar go to google.com click on images type in destroyer and let her go. Were you on a destroyer? I was on the 851.
      FatEddy
      Is there any special way to make a pattern for the Destroyer. I do have a picture of thew ship I was on
      Joelow
        No special way, just blow it up on a copier to the size you want and then draw in the lines where you want to cut with a pen and your done. A lot easier than it seems at first. You can use any scroll saw patern as guidance just to get a general idea of what to do and what not to do. You might want to make several copies of the picture in case you goof (save you a trip to the copier).
          Rolf,
          Are you ok Rolf?
          Today, 05:43 PM
        • Jim McDonald
          by Jim McDonald
          Today, 09:10 AM
          Today, 07:43 AM
        • evilbadger
          by evilbadger
          Today, 06:40 AM
          Yesterday, 08:41 PM
