compound patterns
  • compound patterns
    I am new to scroll sawing and have found my passion!!! I just got Sam Keener's book '128 compound scroll saw patterns' from the library and have made my first 3D figure, a sail boat on one side and a dolphin on the other. I am fascinated by these '2-in-1' designs. Can anyone tell me other books that have these designs, or if Keener has written any more books???
    Thanks, Betsypup
  • handibunny
    by handibunny
    Today, 09:21 AM
  • Bill Wilson
    by Bill Wilson
    Today, 09:06 AM
    Carole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
    Today, 08:40 AM
    That is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
    Today, 07:28 AM
  • handibunny
    by handibunny
    Just a word of caution about the size of the blade hole. When I used a DeWalt years ago in the infamous community woodshop, and also with my more recent experiences with the Jet, if you do much bevel cutting at a steep angle, you will cut into the table. That's why inserts have the slot that can be...
    Today, 06:21 AM
