Has anyone tried the compound saw patterns? I purchased the book by Sam Keener and the instructions are brief and I can't get them to turn out? Any help? Thanks
compound scroll saw
Re: compound scroll saw
The patterns are designed to be folded onto two sides of the wood. Make sure you are using the pattern correctly. It works best if you saw the thinner side of the pattern first, doing this in one continuous cut. Make sure you tape the wood together after you cut out this one side just the way it is, dont take anything apart. Now cut the wide side of the pattern, and after you are done, take the wood all apart and inside is the compound pattern come to life.
Good Luck
:-/Help! I'm also having a problem with Sam Keener 3-D patterns!! Other patterns have the 'fold' line on them. Mr. Keener's does not!? Do I need to make 2 copies of pattern Or just find the most likely place for the fold?? I would appreciate a clarified answer!? Thanks a bunch!!!
Today, 09:52 AM -
by RolfJohn your original post is a valid question. It is a simple thing to put in the original scale assuming that it was on the original drawing. As a minimum the size of the material required can be stated, although that has been a confusion for folks that have built the clock projects. I field a lot of...
Today, 09:22 AM -
by Quartz43Maybe nothing has changed ? But is there anything that can be done to make it easier. The very large projects are difficult to copy over several pages and put together properly. I believe in making improvements and not preserving the status quo.
I enjoy the challenge of cutting a project...-
Yesterday, 08:48 PM -
by keystonecopThis is not a problem with the magazine for my issue.. It is a problem with the book having resized the drawings without giving the actual size.
I do again apologize for my post.. I cannot use the right words to explain it.. so maybe someone should just remove the post....-
Yesterday, 07:29 PM -
by markdavdReading these replies, I am still trying to figure out what the problem really is. I haven't noticed changes in how they publish recently and I don't think I ever had trouble making copies of of the patterns I want to cut.
How did you copy the patterns 10 years ago? What has changed?...-
Yesterday, 06:43 PM -
