IN State Seal Pattern
  • IN State Seal Pattern
    Hi, I am new to creating my own patterns, but not new to scroll sawing and I need a Indiana State Seal patern made. A picture can be viewed by going here: http://www.statelib.lib.in.us/www/ih...s/embseal.html
    That picture has WAY too much detail I need it a little simpler, but with enought detail to make out everything. I can do detailed work, but need a workable pattern, and am lost at creating one. I appreciate any help.
    Re: IN State Seal Pattern
    Hi
    Personally,what I,d do is print the seal and enlarge it to the size I wanted it.And then work from there,using whatever detail I think I would need.Hope this has been of some help.
    Mark
      I have the Pegas replacement table for my EX21. It was the best investment that I made. The best part is they eliminated the useless vacuum holes and reduced the size of the blade hole as well. Another benefit was the table stiffened the EX21 frame eliminating much of resonant vibration. It is a much...
      Today, 09:45 PM
    • KarlB
      Reply to Shawl pins
      by KarlB
      That's what I was wondering Betty: If these would work (larger) for hair?
      Karl...
      Today, 04:47 PM
    • RJweb
      Reply to Shawl pins
      by RJweb
      Who said being bald isn’t a plus, RJ...
      Today, 01:18 PM
      The perfect solution when I need a wider top on my Hegner. A magnetic sheet! I decided not to get the Pegas as the only reason was for the wider top and the top feed blade. After 19 years, my Hegner is still running like new and I couldn’t justify the expense. It was a “want” and not a “need”....
      Today, 12:27 PM
      Reply to Shawl pins
      Good idea Scott. Also, my daughter has long, curly hair. She twists it up and around and sticks a pencil in to hold it. I also stick a dowel in my hair when working and my hair gets in my way and I twist it up. The one in this picture would perfect for thick hair.
      Today, 12:19 PM
