I am looking for a product called PEG. It is used to preserve fresh cut wood to prevent cracking. IE: slab from a tree. The last time I saw it was in a woodworking mag. about 20 years ago.
Looking For---
Today, 10:23 AM -
Today, 10:19 AM -
Today, 07:55 AM -
Yesterday, 08:15 PM -
Yesterday, 05:07 PM -
