There has been a discussion about losing small parts, be they from a scroll saw or, in my case, also from plastic models. I finally got tired of brushing through saw dust on the floor, etc. and made this from a spare water nozzle attachment for my shop vac. I removed the squeegee and attached a piece of window screen. Unfortunately the one view didn't come out well, but the other side is attached in the same manner. It works for me. I do a little vacuuming of the area I lost the piece in, and most of the fine dust goes in my vac. What ever remains on the screen is pretty much visible to the naked eye. I then gently brush it off the screen, it seems to adhere slightly, and Viola! there's the part I'm looking for.
Small Parts Pickup
wow Buzz that is ingenious I will have to make one of those, as a fellow modeler I have lost lots of small parts and looking through the carpet on hands and knees can drive ya mad, thanks for sharing this tipDaryl S. Walters Psycotic scroller with a DeWalt 788
I wish I had seen this earlier. Last year I was sanding some fine pieces for a segmentation project and I had the vacuum nozzle on the drill press with the drum sander.
You know how frustrating it is to have to tear open a vacuum bag and rummage through the contents to find one small piece that was sucked in.
I since put a screen on the vac too.CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Some people put a large airtight drum between the pipe and the shop vac, working on the principle that large pieces will fall into the drum and only fine dust will be sucked into the vac, meaning the bags don't fill up so quickly.
Gill,
In a two stage vacuum (with a separator) the sawdust ends up, with the bigger parts, in the canister too so you don't have to tear a vacuum bag apart, but you still have to dust dive for the parts.
The screen is a good 1st line separator for the use as described above.
Just my unrequested .02 ;-)
Marcelhttp://marleb.com
by millwabIn preparation for a scrolling demonstration I decided to make up a piece that would show the different ways I've cut puzzles. It's 2 layers of 1/8" BB. The puzzles were cut out as tray puzzles and then glued back in so pieces wouldn't get lost as it was handled.
Channel: Scroll Saw Puzzles
Today, 04:41 PM -
by jim_mexUpdate at 13 April – Its been almost a month since my last post and my shop extension is progressing albeit slowly largely due to me nibbling at it on a regular basis rather than sticking with it and going full blast to get it finished.
The outside of the extension is almost finished apart...-
Today, 03:45 PM -
Reply to New Toy!by RolfQuartz I only bought the air filter, That same model is sold by many distributors, I see Grizzly has it and several others. I was going to build one but this thing works great. I will get a charcoal filter for it also. Great when doing Pyrography. They also had a Pfingst brand flex shaft tool I haven't...
Today, 07:50 AM -
