puzzle question
  • puzzle question
    I would like to try and make my own Christmas puzzles.
    What do you use to glue the picture onto the 1/4" birch plywood?
    Diane
    Dragon
    Owner of a nice 21" Excalibur
    Owner of a Dewalt 788
    PuffityDragon on AFSP
    Different people using different things, Diane. I use 3M super 77 spray and it works for me. Others on here - including Carter I think - use Aleene's tacky glue ..
    Ian
    Scrolling with a Dewalt 788
      Thanks Ian. I will look and see what is available around here.
      Diane
      Dragon
        Diane, I used regular Elmer's Carpenters' Glue for many years before discovering the Aileen's Tacky glue mentioned above. Whatever you use, spread it on the wood in a thin, even coat with a paint scraper and then put the card down on the glued surface while slowly smoothing with your finger from one corner to the other.
        Don't go away. Stay close for awhile and, every couple of minutes rub your finger along the edges to make them stay down. Also hold it at an angle to the light so you can see and smooth any bubbles that form.
        When the glue is dry, cut the edges. Then spray it with a glossy spray for protection.
        And then start cutting the pieces.
        Here's a picture of our card from 03, one of my favorites. The assembled card is in the middle of the picture with all the pieces around it.
        Have phun.....Carter
          glue answer
          i use Elmers spray glue for all paper to wood gluing works great heat gun takes off the paper when done cutting and paint thinner takes off teh glue left behind
            Diane
            The 3M is available at Canadian Tire and Staples round here - think I've seen the Aileene's in Zeller's and/or Michael's.
            Ian
              Thanks all for your answers. Ordered some puzzle blades from Mike on Monday and they should be here soon. Checking for the glue tomorrow on my way to the city.
              Diane
              Dragon
                puzzle picture glue
                Dragon,
                I use a product called MOD PODGE. Available in AC Moore and Michael's craft stores here in NJ. The only drawback I have found is that being water based it can pick up the ink from a picture that you print out using an inkjet printer and give it a slightly fuzzy look. I use it both the adhere the picture to the wood (once it is dry it will not come off) and to coat the picture after it is adhered. This also seals the wood if any is still exposed and prevents the picture from wearing out. Again, the only drawback is that it may give the picture a slightly fuzzy look due to the brush strokes which I can't seem to get out.
                George
                delta 650, hawk G426
                  When my father died my mother gave me a huge container of mod podge and I never knew for sure what to do with it. I will give it a try. Thanks
                  Diane
                  Dragon
                  • Quartz43
                    Looking For Mom and Baby Animal Pattern
                    by Quartz43
                    I made these simple animal patterns some time ago and gave to my Grandkids. They play with them a lot and have gotten broken so I need to make new ones. Of course, I can not find the pattern and can not remember where I have seen it.
                    Can anyone tell me where to get the pattern?
                    Today, 09:48 AM
                    Reply to Giraffe Scene and Puzzle
                    Well that is a new one! What a clever combination! looks great.
                    Today, 09:27 AM
                    Reply to Blades
                    I have grown to like the Pegas brand MGT blades . for this thickness the blade number varies from brand to brand, The TPI (teeth per inch) is more important the Pegas 5 is 11.3 and the 7 is 10.4 TPI.
                    I also the Olson Mach series the #7 has 8 TPI and really works great on thick wood....
                    Today, 09:23 AM
                    Farmers market
                    The sales at my market is off the charts. We do Saturday and Sunday but I’m home cutting for next week and Bruce is there for the 3 hours today mostly for pick ups. My entire stock inventory is just about gone! Bruce made 8 pepper grinders. Only 1 left. Angels, birdhouses flying off the trees. Baskets...
                    Today, 09:17 AM
                    Reply to Recommendations anyone?
                    I have a Micro Mark drill press that I use for the tiny holes when doing delicate fretwork. I am happy with that.
                    This saw is too limiting especially for any bevel cuts. The blade change process would drive me nuts, and the other concern is blade tension. It is like the ancient deltas, spring...
                    Today, 09:15 AM
