Wood Stacking & Blade Selection?
  • Wood Stacking & Blade Selection?
    Need some advice. I'm wanting to start on a JZ pattern that I've been holding on to for a couple of years now. "Engine 86" He suggests stacking at least three 1/8" to 1/4" plywood piece together and use Flying Dutchman 2/0 spiral blades. Not questioning what he is suggesting, I'm just not comfortable with spiral blades. (yet)
    My main concern is if I use non spiral blades should I still stack the wood to help support the fragile pieces? Haven't stacked any of my work yet but this pattern seems to have longer, thinner cuts. Wondering if I should get comfortable with spiral blades and put this one off a little longer? Or plow ahead?
    Troy
    Scrollin' with DeWalt DW788
    Troy, I cut "Engine 86" from one piece of 1/8" birch plywood with straight blades, only had one mishap in a place that shouldn't have broken. I used a blade a little too long, it was on the cow catcher. I soon learned to keep a sharp blade in the saw while cutting that one. Click on the picture to make it larger. I fastened N guage track to the frame.
    Mick, - Delta P-20
      Troy, forgot to tell you that I used 2/0 28 t.p.i. reverse tooth blades. I cut all the smallest pieces first working my way up to the larger ones. I taped the cut pieces back in place in the fragile areas. The most difficult one I have cut so far. Have fun with it , it is a challenge. There are a lot of long floppy ones to cut.
      Mick, - Delta P-20
        I would always stack cut something like this for several reasons (I usually cut 3 up 1/8). 1. the support. 2. It gives you more control. (easier to cut thicker than a single thin piece. 3 Most importantly someone will see it, love it , and have to have it. So now you either sell the other 2 or make someone very happy with an awsome gift.
        For Jeff stuff I use the FD "new 2/0" spirals. Although in some areas I use the straight blades.
          Nice cutting Mick, and the track around the frame is very "ENGINIOUS".
          kevin/pitbull.
            Great cutting Mick - and that's a a very nice pattern. I like the track round the frame too - an inspired touch ...
            Is it just me or do other people think that JZ does himself a disservice by having such small pics on his site. I understand the pattern theft issue but I find a lot of his patterns aren't big enough for me to get an idea of what they really look like ..
            I've ordered a couple after seeing other members pics on here, rather than seeing the pics on his site ...
            Oh Troy - sorry to go off on a tangent on the thread - beginner with spirals here too - but I've found no problem cutting 2x 1/4" birch ply with 2/0 spirals - other than the odd bit of human error ..lol Cutting 2 stacked is easier than cutting 1 x 1/4" in my opinion, aprt from the fact that as regards time and effort you may as well have at least one extra cutting ...
            Ian
            Scrolling with a Dewalt 788
              I love the frame idea! Great job cutting too!
              Mia
              We are the music makers.
              Easy scrollin' with a DW788
                Mick, looks good, excited about getting started on mine. Thanks guy's for all the information, I'll take it all in & start working on it soon.
                Troy
                  I agree wholeheartedly with Rolfs' reasoning which is why I suggest stacking... Of course you can cut it in a single piece if you choose to do so
                  Will be interested to hear if you decided to go with flat blades or spirals.
                  You may consider Rolfs' suggestion there too... for the areas you decide to cut with the spiral try the "NEW" FD spiral (less aggressive, easier to control and cleaner cut) and then use a flat blade for areas you aren't comfortable with the spiral.
                  Spirals do require a different "touch" but with some practice I am sure you will get the hang of them.
                  PuzzledMoose going to send you a PM about the images... let me know if you don't get it
                  Good Luck Troy, please share a pic of the finished cutting!
                  Jeff Zaffino
                  Shadez
                  Advanced Scroll Saw Patterns
                    Thanks Jeff, always get great advice here. I'm going to start this weekend on it. I think I'm going to go straight blades on this one though.
                    Troy
