i am relatively new to scrolling but a man i met at a craft fair suggested thaT i cover the wood with brown packing tape,spray the pattern with adhesive ( I USE 77) after finishing cutting the tape is very easy to remove and leaves very litle residue. a light sanding is sometimes needed when i've used thin plywoods,on solid wood i have not experienced and lift or residue. also the tape seems to act as blade lubricant.
packaging tape
Today, 09:52 AM -
by RolfJohn your original post is a valid question. It is a simple thing to put in the original scale assuming that it was on the original drawing. As a minimum the size of the material required can be stated, although that has been a confusion for folks that have built the clock projects. I field a lot of...
Today, 09:22 AM -
by Quartz43Maybe nothing has changed ? But is there anything that can be done to make it easier. The very large projects are difficult to copy over several pages and put together properly. I believe in making improvements and not preserving the status quo.
I enjoy the challenge of cutting a project...-
Yesterday, 08:48 PM -
by keystonecopThis is not a problem with the magazine for my issue.. It is a problem with the book having resized the drawings without giving the actual size.
I do again apologize for my post.. I cannot use the right words to explain it.. so maybe someone should just remove the post....-
Yesterday, 07:29 PM -
by markdavdReading these replies, I am still trying to figure out what the problem really is. I haven't noticed changes in how they publish recently and I don't think I ever had trouble making copies of of the patterns I want to cut.
How did you copy the patterns 10 years ago? What has changed?...-
Yesterday, 06:43 PM -
