I am new to scroll sawing and have been doing it for a couple of months now. I have a Delta 16 inch variable speed. I only use wood that is no more than 1/4 inch thick. I have made shelves and fancy boxes etc., but I am having a problem with the blades staying in. I use normally size 2 or 3 for the detailed fret work, but a lot of the time I cannot get the blade to stay in when I push the lever back to tighten the tension. The top blade slips out sometimes and I have to stop to put it back in. I have turned the little knob that adjusts for the small blades according to the manual, but this doesn't always help. I have tried moving the blade higher in the clamp, but sometimes then when I start it comes out of the bottom clamp. This can be quite frustrating when I have a lot of detailed things to do where I go into a new hole quite often and then the blade slips out. But it doesn't happen every time, but often enough to be frustrating. I don't want to have to use a larger blade because then I can't manouver as well around the curves and small pieces. Any advice would be appreciated. Other than that, the saw works great.
Help with blades
Today, 09:52 AM -
by RolfJohn your original post is a valid question. It is a simple thing to put in the original scale assuming that it was on the original drawing. As a minimum the size of the material required can be stated, although that has been a confusion for folks that have built the clock projects. I field a lot of...
Today, 09:22 AM -
by Quartz43Maybe nothing has changed ? But is there anything that can be done to make it easier. The very large projects are difficult to copy over several pages and put together properly. I believe in making improvements and not preserving the status quo.
I enjoy the challenge of cutting a project...-
Yesterday, 08:48 PM -
by keystonecopThis is not a problem with the magazine for my issue.. It is a problem with the book having resized the drawings without giving the actual size.
I do again apologize for my post.. I cannot use the right words to explain it.. so maybe someone should just remove the post....-
Yesterday, 07:29 PM -
by markdavdReading these replies, I am still trying to figure out what the problem really is. I haven't noticed changes in how they publish recently and I don't think I ever had trouble making copies of of the patterns I want to cut.
How did you copy the patterns 10 years ago? What has changed?...-
Yesterday, 06:43 PM -
