1st Wooden Letter Opener
  • 1st Wooden Letter Opener
    Here's my first attempt. Pattern came from a Spielman book. Wood is 1/4" solid cherry (I think). Cut w/ a #9 on the outside and a #5 on fretwork. Finished with BLO. Length is about 7 3/4".
    Tapering the blade area wasn't as hard as I thought but will still take a bit of practice for best results. Also had trouble finding a good font for the Letter and finally settled on an Old English style.
    Mike
    Scrollin' since Jun/2006
    My Gallery
    Mike,
    Very nice work.
    Doc249HMCS
    Excalibur 21, and a Dremel 1680
      Great work Mike
      Charlie
      Craftsman 18in. 21609
        Neat little project Mike. But is it sharp enough!?
        Paul S.
          Looks good, Mike - so how DID you shape it?
          Ian
          Scrolling with a Dewalt 788
            Sharp enough to cleanly split a folded sheet of 20lb paper. I think the trick there is to use hard wood so the edge will hold.
            Shaping was done on a 1" belt sander. First, I drew a pencil line down the middle of both edges to serve as a guide. I used a straight edge for that but just eye-balled it. I gradually sanded down each edge to that line. Then with very light pressure I rocked the blade back and forth to round off both sides.
            I've got another done in a slightly different pattern that I'll upload later. BLO is drying.
            Mike
            My Gallery
              Mike, That turned out really well. And just think you were worried about shaping it. Steve
              My Gallery
              [email protected]
                Looks wonderful Mike!! I trick I've learned from making all the pocket knives lately is to coat the blade with CA Glue (super glue is actually cyanoacrylate (or something like that)) LOL Talk about adding some extra strength to the edge. I do the sanding with a belt sander, clean it up and touch it up with elbow driven sander and then use the brush on CA Glue. It's Locktite brand from the local hardware store. Let the glue dry, it'll soak in and really seal up the grain, then touch up again with sandpaper and steel wool. It doesn't seem to affect the oil finish but the edge stays on the blade wonderfully. It's a common practice with pen turners and carvers to use CA glue and I don't make a knife now without it.
                Andy
                Shoot for the moon. If you miss you'll be headed for a star! www.80artdesigns.com
                  Thanks for the glue tip, Andy. I'll have to find some and try it. I plan on making more openers, perhaps with logos or images like planes. Right now I'm try to find a use for some small scrap wood so the designs will be relatively small.
                  I Google CA Glue and found it sold at Hobby Lobby. Theycarry two viscosities: thin and medium. Which is suitable for the opener?
                  What kind of wood do you use for your knives?
                  Mike
                  My Gallery
                    Great work!
                    Mia
                    We are the music makers.
                    Easy scrollin' with a DW788
                      Very nice work Mike.
                      I like the choice of font.
                      Which Spielman book did you get the pattern from?
                      Regards,
                      Marcel
                      http://marleb.com
                        Definitely the thin CA glue Mike. It dries really fast, obviously, but in the 5 or 10 minutes it takes to dry the thinner the better so it can soak into the grain. Then when you finish sand to remove any streaks, drips, or runs, only sand what's necessary and you'll have the added strength. I haven't been able to find anything locally over a 4 oz. bottle and I prefer the brush on. It's just a bit easier to control where it goes on, but does require a bit more sanding. I'd encourage you to practice on a scrap and that'll get rid of one small piece you don't know what to do with. LOL
                        Andy
                          Regards,
                          Marcel
                          It's here, Marcel ..
                          http://www.scrollsawer.com/forum/inf....htm#post65331
                          Ian
                            nice job. Looks great
                              Some great work there Mike.
                              Lou
                              Lou
                              Craftsman 18 in.Variable Speed Scroll Saw-21609
