Live Laugh Love paper
  • Live Laugh Love paper
    cut about twenty five of these today think they turned out ok
    Very Very Very nice. I like that way you mounted and frame it too. It all works well together.
      I'm sure Toni & Sue will be delighted to see this !
      Nicely cut and photographed, Jerry .
      Gill
        Nice a crisp and clean looking. What's the "Paper" part refer to?
        Jeff Powell
          I would assume that it is cut out of some sort of paper. Very nice.
          Diane
          Dragon
          Owner of a nice 21" Excalibur
          Owner of a Dewalt 788
          PuffityDragon on AFSP
            paper
            the paper I do cut things out of is about the thickness of card stock. I do cut wood also How ever I cut alot of patterns from paper stock for an old age home >when cutting paper you can stack about 25 together for a one time cut This took about 40 min for all
              Ah you have made me smile! Thanks for sharing your cuts of the design... and twenty five huh? Cool!
              Love the completed project.
              Take care
              Toni
                25/40 = 0.625 mins to cut each one ... wow, that is production cutting ...
                It looks great GF.
                Ian
                Scrolling with a Dewalt 788
                  Very nice! Using the card stock is very creative, too, never heard of anyone doing that before.
                  So how do you go about preparing your stack for cutting?
                  Pete
                    reply for cuting paper
                    I use 1/8 ply birch for back and front ,than brad nail the four corners front and back glue pattern ( Elmers Spray) drill holes and cut pattern after cutting pattern out I use a heat gun to remove the pattern from the wood ,This gives me 25 paper cut out and two wooden ones for painting or staining
                      What blade do you use for those, Jerry?
                      Ian
                        very NICE!!! I like what you've done and really apppreciate your letting us know how you did it!! Thanks!
                        Sue Chrestensen
                          I have never tried it but it seems you would get fuzzy edges (which you don't). Is that because of the tightness of the pack or the blade you use?
                          EarlinJax
                          (suddenly a senior member)
                            Thanks for sharing you method, GF. Those would be especially nice for charity fundraisers, I think.
                            It also makes me think about scrolling Christmas cards this year.
                            Pete
                              Blade size
                              2.0 olson blade on these some time i 'll use a 3 however most paper is a 2.0
                              • handibunny
                                by handibunny
                                Rolf, smaller bowl-cutting angles, 30Ëš or less, usually don't present a problem either with vibration or for cutting into the table. It's when you get into the 40Ëš and 45Ëš range that things get dicey for both. (The Seyco saw doesn't even cut bevels greater than 35Ëš or so!) If you add even a slight...
                                Today, 09:21 AM
                              • Bill Wilson
                                by Bill Wilson
                                Today, 09:06 AM
                                Carole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
                                Today, 08:40 AM
                                That is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
                                Today, 07:28 AM
                              • handibunny
                                by handibunny
                                Just a word of caution about the size of the blade hole. When I used a DeWalt years ago in the infamous community woodshop, and also with my more recent experiences with the Jet, if you do much bevel cutting at a steep angle, you will cut into the table. That's why inserts have the slot that can be...
                                Today, 06:21 AM
