I cut out this wolf before it got cold in the shop and I still don't have a finish on it.
The wolf was out of 3/8" Cherry and the stand is 1/2" walnut.
You did a beautiful job with it. Great paintwork! I can see Carving the prop out of one piece considering the grain direction changes etc. was a challenge.
By the way, I did not follow the dimensions exactly as I just used scrap wood that was lying around and scaled to fit - also, for the propeller, I decided to make it from a single block - that turned out to be slightly more difficult than first imagined... but it works!
Hullo (in Scottish) or Hi in 'Murican?
I stumbled across this site by accident while looking to keep my idle hands busy as I was hunting for easy whirligig patterns. I found some old plans by Mr Paul Meisel from about 10 years ago about a P31 Mustang here https://scrollsawer.com/2009/08/28/ai...
