I am sorry, but I have read a lot of posts. Did I see one that stated about tilting the saw forward? If so why? If I am wrong,Sorry! I have been out of this for a while!
Pep
Just makes it easier to see what you are doing if its tilted slightly forward.
I have used my scroll saw with the table level and tilted forward and so far I am partial to it being slightly tilted(just easier for me to see what I am doing)
i've been trying the tilting saw idea out as i suffer with neck and shoulder problems and i have to say it works for me, i raised the back with a piece of 4''x4''.
And this helped? I too have neck and back problems to the tune of 9 deteriorating disc's. I raised the saw so I didn't have to bend down so far to work and added a stool, but was thinking about raising the back a bit to get a better downshot on the work in progress. I saw plans for a saw table earlier this week that actually has a tilt mechanism built into the table. I was wondering about the vibrations it may enhance. My saw attaches to my work table with 'T" tracks and star knobs so I can remove it easily when I'm working on something that takes up the whole table. I could add the tilt to the platform the saw sits on so it becomes part of the base.
Pop Delta 16" 40-530 Ryobi 16" VS
"Never be afraid to try something new. Remember it was amateurs that built the ARK but Professionals that built the Titanic!"
Thanks for the info, I will give it a try, and being 5'3" and a half ( I'm proud of that 1/2" ) This might help, I cant get my table any lower!
Thanks
Pep
in reply to pop, i have spondulosis in the top of my spine which gives me limited neck and shoulder movement and i was having real discomfort whilst using the saw so iraised it up an inch at a time till i was happy with the height, i still have pain but that is not getting aggrevated by using the saw, i have'nt really noticed about vibration my saw is'nt even bolted down as i only have a small workshop with limited space so i need to be able to move it about, but i am thinking about trying to re-arrange everything ( i'm having a new kitchen sometime this year so i'll have a few kitchen units to use use as benches) planning,planning,planning, it never stops does it?
Pop,
I'd love to see photos of your setup! That sounds like a great idea!
Do you get Woopdpost (a quarterly put out by Lowe's)? They were down about 2 months ago and did a piece on my shop and some of my projects for the Spring issue. Should be out in March I believe. It probably won't show much of the shop even though he took over 3 hours worth of pictures. They usually only do a short write-up a 1 picture.
I got hooked on using 'T' track from Rocklers when I built a special work table for on my drill press. It was my Dad's and is over 70 years old so there are no easy adjustments. The table I made for it goes up and down and has out feed tables built in with 'T' track every where. It holds the different jigs, sanding attachment, fence, etc. That's when I decided to use it on the work bench too. I made my own router table with a lift and... of course... 'T' track for different attachments on the top. The scrollsaw was the first thing I made a base for that attaches with them to the work bench. I have a very small shop (16x20) and it has to be very flexible to hold my woodworkign and Model A Ford supplies, so removeable jigs and fixtures are a must.
Pop,
Here you go... It's posted with a couple more shots of "T" track use in the "Show us your saw " thread.
I tryed the telting my saw thing. and I have to agree, I could see much better. BUTTTT when turning my wood, well. My body got in the way. drats. when tuning my wood, some of my body parts got in the way. soooo I put it back. I really like the idea. but need to compensate for turning the wood. I could see how this might help in spirals. I need to try that next. your friend Evie
I am sorry to hear that people are having so many issues getting the vaccine. Indiana seems to have a great system. I signed up online with no problems. When I went for my shot they had numerous stations to check in and numerous stations to get your shot. Some giving shots were volunteers from the...
NC opened it up to 65+ the week of January 11. It took us an hour plus to get appointments online through one of the major hospital systems. We had to go to separate places but both my wife and I had our first dose of the vaccine on January 21st and appointments for the second one on Feb 23rd. The...
