Hi everyone. I just bought a Hawk 220 on e bay. It has a single on-off switch on the right side. Underneath, on the gearbox ( ??) it seems to have a step pulley. The belt is on the smaller pulley. Should there be a second, larger belt for when I want to switch to the other one? I would ask about blade changing and tension adjustment, but all that should be in the owners manual. Oh wait a minute... I don't have one of those ! Can any one say, from experience, which exact model this is ? The factory couldn't track the serial number, but guessed the saw is mid to late eighties . The Hawk site has several PDF manuals , but I'm not sure which one would apply. Thanks in advance for the help..... Larry
Identify an older Hawk for a newbie??
Old Hawk
I may be a little confused here, but my original Hawk, many years ago, had a step pulley. All you had to do was to force the belt on the larger pulley over to the small pulley on the same shaft. Then go to the other pulley on the 2nd shaft and force the belt from the smaller pulley over to the larger pulley. If you add the diameters of the large to small pulleys and the diameters of the small to large pulleys, they should come out the same. My lathe has the same set up only it is a four step pulley setup.Buzz
Thanks Buzz and Romescroller , I think I figured most of it out now. The factory has nailed it down to 1985-1988 . You were right about the PDF manual, and that's the one I have downloaded. I was hoping I could just change the belt from one pulley to the other, but it has a single pulley on the motor, and a step on the gear box. Instructions say to remove belt , flip dual pulley over, install longer belt, adjust belt tension by sliding the motor, and then tighten everything back down. Sounds like a PITA , but I ordered the belts anyway, just in case I want to do it. Please explain more about updateing the upper arm..not sure I follow. I did order modern blade holders for the saw. The originals require a few tools to change the blade, the new ones are the "tool-less " varity. Thanks for all the help on this, I'm really looking forward to many good years out of this machine. LarryLarry
Dewalt 788 Owner "I love wood , with or without Mandolin strings"
Wow Doug , I bet that was a pricey upper arm. Not sure if I'm ready for that exspense. As soon I can convince the wife that I am a dedicated scroller, I hope to be able to buy a more modern (variable speed) machine. ..LarryLarry
Reply to Eagleby Sandy OaksI agree, a beautiful piece and wonderful cutting. Years ago, my father had Alzheimer. The last six months we had him in the VA center in St. Cloud MN. His wood work shop is still in MN. I could not take it down to TN....
Today, 12:00 PM -
Today, 09:16 AM -
Today, 05:27 AM -
Reply to My lucky day!by will8989🍷🍷MD is a cluster mess. Getting the vaccine is fast. Getting the appointment is another story altogether. The county executive makes the rules for their own county. State says 65+ the jerk that runs this county says no, 75+ then puts a whole bunch of people on a priority list. But, there are state...
Yesterday, 09:18 PM -
