Hi EveryOne, here are a couple of pictures of some special orders that I designed. The Broken Wheel Campground is located near Stonewall Jackson Lake, WV. The Treed Black Bear is for a bear hunting club. Steve
Original Designs
Nice work Steve, I've never seen a treed bear pattern before, as a twist have you ever thought of a treed dog and a pack of bears at the base...no really I am serious it would be a riot.Todd
Hawk G4, Dremel 1800
Quando Omni Flunkus Moritati
Todd, that would be a hoot. It brings to mind the buck deer with the rifle. I designed the treed coons first for another hunting club that have coon hunts. The group from the local bear hunters assoc. wanted me to do a bear. The original coons has a mini clock. SteveLast edited by Steviegwood; 12-28-2006, 08:24 PM.
Sign
Steve. The sign is absolutely GREAT!!! If it is to be used outdoors, what kind of glue did you use? It must have been quite a trick getting all the letters in their proper spacing and then gluing them so none of the glue showed around the edges.Buzz
Sign
Originally posted by BuzzSteve. The sign is absolutely GREAT!!! If it is to be used outdoors, what kind of glue did you use? It must have been quite a trick getting all the letters in their proper spacing and then gluing them so none of the glue showed around the edges.
I have used Elmers yellow glue for years. Lately I have been using Aleene's, both original and thick Tacky Glue. The best part of this is it dries clear. It's almost impossible to see squeeze out. Also, I haven't had a holding problem although I haven't used it under extreme situations. I mostly use it for scroll saw projects, desk name plates, wall hangings etc. I just fixed a wooden chair for our oldest daughter using Aleene's. Only time will tell if it holds.Buzz
Nice job, Steve. I love to see all the photos. Can sometimes spark inspiration. Thanks for sharing.Mike
Scrollin' since Jun/2006
My Gallery
Today, 10:59 AM -
Today, 09:46 AM -
Channel: Scroll Saw Puzzles
Today, 09:26 AM -
Project size 6 x 5,5 inches
Video of making trivet
Trivet pattern
Today, 09:08 AM -
Yesterday, 09:54 PM -
